RSorder-OSRS: Beginner Guide to Giant Foundry and Extreme Hammering
Postat: 15 jun 2026, 11:26
av Seraphinang
Tired of the repetitive grind at the anvil? Giant's Foundry lets you gain XP while actively playing, making the rush to level 99 much easier. But are you struggling to get in? Unsure about the right gear? Worried about messing up the process and missing out on rewards? We've compiled a complete guide covering everything from requirements to the workflow—read this, and you'll be ready to start grinding smoothly. Want to stock up on materials quickly for an uninterrupted level-up rush? Head straight to RSorder to OSRS gold and boost your game level!
Getting In: The Mandatory Prerequisite Quest
Many players find the location but get turned away at the door; the main reason is often missing the "Sleeping Giant" quest. This is a strict requirement for entry—without it, you simply cannot get inside. The quest itself is short and acts as a free, official tutorial: you'll talk to NPCs to learn the foundry's layout and gather starter materials to practice the core mechanics of heating, shaping, and cooling. Completing it permanently unlocks the minigame, giving you hands-on experience so you can start taking contracts and grinding levels immediately.
Stocking Up: Bring the Right Gear to Double Your Efficiency
Once the quest is done, you can enter, but preparing the right items beforehand saves you a lot of wasted time and prevents mid-grind trips to restock supplies:
Core Essentials: Stockpile Metal Bars for Uninterrupted Grinding
The entire forging process at Giant's Foundry relies on metal bars; crafting a weapon consumes a specific amount. You can use anything from Bronze and Iron to high-level bars like Mithril. Higher-tier metals unlock better contracts and yield more XP. We recommend stocking up before you start so you can run multiple rounds without leaving to gather more resources, keeping your leveling momentum going strong. Cooling Options: Free Buckets vs. Speed-Boosting Ice Gloves
Cooling the high-temperature mold is a mandatory step. Beginners who haven't unlocked special items need not worry; free buckets are available right inside the Foundry, though making a trip to grab one each time is a bit of a hassle. However, if you have completed the "Hero's Quest," be sure to equip Ice Gloves. They allow you to handle hot metal directly without constantly fetching water, saving significant travel time and boosting your operational speed—a must-have for efficiency-focused players.
Optional Optimization: Pre-stocking Materials for Specific Contracts
If you accept a special contract requiring a specific shape and material, prepare the corresponding metal bars in advance. This saves you the trouble of running back to the bank mid-process.
Whether you are leveling up or crafting gear, having plenty of gold makes the experience smoother. Get OSRS gold instantly at RSgoldfast and enjoy the game to the fullest!
The Full Process: Follow Every Step Carefully to Maximize Rewards
Once you enter with your supplies, follow these steps for every weapon contract. A single mistake can lower the weapon's quality and reduce your XP gain, so keep this in mind:
1. Choose the Right Mold: The mold determines the weapon type and required materials. Different molds offer varying XP and consume different amounts of bars; simply choose based on your current level and the materials you have stockpiled.
2. Control the Temperature: After placing metal bars in the furnace, keep a close eye on the thermometer. Temperatures that are too high or too low will degrade the weapon's quality. Wait until the temperature is in the optimal range before proceeding—don't rush and make careless moves.
3. Pour Precisely: Pour the molten metal into the mold only when the temperature is correct. Greater precision results in higher weapon quality, yielding better rewards and more XP upon completion.
4. Don't Forget to Cool: You must cool the item before finalizing its shape. You can use either a bucket or Ice Gloves; this step prevents weapon damage and ensures a successful delivery.
5. Deliver and Claim Rewards: Hand the finished massive weapon to Kovac to receive Smithing XP and Foundry-exclusive rewards. That completes the entire process. Tips for Efficient Leveling: Master These to Gain XP Faster Than Others
If you want to reach Level 99 faster, be sure to use these tips compiled by veteran players:
Keep your inventory streamlined; don't carry useless clutter that causes you to fumble and waste time when looking for items;
Experiment with different mold combinations—different levels and materials require different molds. Finding the one that suits you best maximizes your XP gains;
Always check your metal ingot reserves before starting; running out of materials mid-run disrupts your rhythm. Stocking up beforehand ensures you maintain a steady leveling pace;
Check out tips from community experts; the OSRS forums and wiki are full of strategies to optimize XP and profits. Using proven methods is far more efficient than trial and error;
Take a break after an hour or two of grinding—don't push yourself too hard. Staying fresh helps maintain efficiency and prevents burnout that might make you quit the game entirely.
Pro Tips
1. Bring at least 20 metal ingots for your first run; entering without materials means leaving empty-handed—a total waste of a trip;
2. Don't rush the "Heroes' Quest" just to unlock Ice Gloves; using a bucket of water works fine for getting started, and you can switch over once you unlock the gloves later;
3. For faster XP, prioritize molds that match higher-level metal ingots. If you have the materials, the XP gain is significantly faster than with lower-level ones;
4. Power-leveling Smithing to 99 requires a massive amount of metal ingots. Instead of slowly mining to gather resources, simply buy coins at mmoexp to boost your game level and secure that 99 Smithing cape sooner.
The Giant's Foundry transforms the otherwise tedious Smithing grind into an engaging, interactive challenge. By meeting requirements, preparing the right gear, and following the correct process, you can gain XP while having fun—offering a far better experience and higher returns than the traditional anvil method. Follow this guide to kickstart your leveling journey and achieve 99 Smithing. Want to gather materials quickly for the grind? Head over to RSorder to buy RuneScape gold and boost your game level now!
