Can One Drop Really Be Worth Over 100 POE2 Currency?
Still farming Abyss, Breach, or other traditional currency strategies? What if a single drop could be worth 100, 150, or even more Divine Orbs? That's exactly why Lineage Supports have become one of the hottest endgame farming targets in Path of Exile 2. But where do these ultra-valuable support gems come from? Why do some players discover multiple Anomalies every day while others never seem to find one? In this guide, we'll break down the most efficient way to farm Lineage Supports, optimize your Atlas setup, and maximize your chances of landing one of the game's most valuable drops.
Why Are Lineage Supports Worth So Much?
Lineage Supports are among the rarest and most sought-after endgame drops in Path of Exile 2.
Some variants provide powerful bonuses for specific builds, making them highly desirable on the trade market. As a result, the rarest versions can sell for well over 100 Divine Orbs.
Key Takeaways
Some Lineage Supports are worth 100+ Divine Orbs.
Top-tier versions can exceed 150 Divines.
One lucky drop can outperform hours of traditional farming.
They are among the highest-value endgame rewards currently available.
Who Is This For?
Currency farmers
Trade-focused players
Endgame Atlas runners
Value for Players
A single drop can generate massive profits and significantly accelerate wealth accumulation.
The Real Secret: Anomaly Maps Are the Key
Many players know Lineage Supports are valuable, but fewer understand where they actually come from.
The primary source is Anomaly Maps, special locations that appear throughout the Atlas.
Common Anomaly types include:
Water-themed Anomalies
Desert Anomalies
Vampire-themed Anomalies
Other unique Atlas encounters
Among these, the most valuable are typically:
Water Anomalies
Desert Anomalies
These encounters have access to some of the most expensive Lineage Support drops in the game.
Key Takeaways
Lineage Support farming revolves around Anomalies.
Water and Desert Anomalies offer the best rewards.
Finding more Anomalies directly increases your profit potential.
Who Is This For?
Players interested in long-term farming strategies
Atlas explorers
Value for Players
Provides a clear farming target and eliminates inefficient map grinding.
The Atlas Setup That Reveals More Anomalies
If you want consistent results, your Atlas tree matters.
The most important passive is:
Unforeseen Threats
This node grants a chance to reveal nearby Anomalies whenever you complete a map.
Although the percentage appears small, it adds up quickly over hundreds of map completions.
The second essential passive is:
Untold Histories
This significantly improves your chances of obtaining Lineage Supports from relevant encounters.
Key Takeaways
Prioritize:
Unforeseen Threats
Untold Histories
Then invest in:
Map sustain
Item quantity
Additional reward scaling
Who Is This For?
Players with Atlas progression unlocked
Dedicated endgame farmers
Value for Players
Improves both Anomaly discovery rates and overall farming efficiency.
Unlocking Anomalies: Don't Skip This Step
Finding an Anomaly doesn't immediately grant access to the reward.
Most Anomalies require players to complete nearby objectives first.
These objectives usually appear around the Anomaly as swirling markers on the Atlas.
Once completed, you can:
Unlock the central Anomaly encounter
Access the special map
Challenge the final boss
Defeating the boss gives you a chance to obtain a Lineage Support.
Key Takeaways
Discovering an Anomaly is only the beginning.
Surrounding objectives must be completed.
The boss encounter is where the rewards come from.
Who Is This For?
New Atlas players
Anyone unfamiliar with Anomaly mechanics
Value for Players
Prevents missed opportunities and wasted Atlas progression.
Want Faster Profits? Speed Is Everything
When farming Lineage Supports, map completion speed matters more than full clears.
Many experienced players use a Boss Rush strategy:
Enter the map.
Rush directly to the boss.
Complete the map.
Move immediately to the next one.
The faster you complete maps, the faster you reveal new Atlas areas and discover additional Anomalies.
Key Takeaways
Map completion is more important than full clearing.
Fast builds have a major advantage.
Boss Rush is often the most efficient approach.
Who Is This For?
Speed-farming players
High-mobility builds
Value for Players
Increases profit per hour and maximizes Anomaly discovery rates.
Combine Abyss With Lineage Farming for Stable Income
If you don't want to rely entirely on rare drops, combining Anomaly farming with other mechanics can smooth out your profits.
The most popular choice is:
Abyss
Benefits include:
Consistent currency generation
Excellent compatibility with Boss Rush gameplay
Other viable options include:
Strongboxes
Breach
Expedition
The goal is simple: earn extra rewards without slowing down your map completion speed.
Key Takeaways
Abyss is the best complementary strategy.
Speed should remain the top priority.
Combines stable income with jackpot potential.
Who Is This For?
Dedicated currency farmers
Players running long farming sessions
Value for Players
Reduces reliance on luck while maintaining strong profit potential.
Pro Tips
1. Prioritize Water and Desert Anomalies
These have access to some of the most valuable Lineage Supports available.
2. Don't Full-Clear Every Map
Fast completions generally produce better long-term results.
3. Prioritize Core Atlas Passives
Unforeseen Threats and Untold Histories should be obtained as early as possible.
4. Use a Fast Build
Movement speed and boss-killing efficiency directly affect your profits.
5. Pair Anomaly Farming With Abyss
This provides a reliable baseline income while you chase high-value drops.
Final Summary: What's the Benefit for Different Players?
Currency Farmers
Core Benefit:
Access a high-profit alternative to traditional farming methods.
Potentially earn 100+ Divines from a single drop.
Endgame Players
Core Benefit:
Maximize Atlas efficiency.
Gain access to some of the game's most valuable rewards.
Trade-Focused Players
Core Benefit:
Acquire rare, high-demand items.
Generate significant profits through market sales.
Speed Farmers
Core Benefit:
Convert fast map completion into higher rewards per hour.
Discover more Anomalies in less time.
Casual Players
Core Benefit:
Learn a valuable endgame mechanic.
Explore a rewarding alternative to standard mapping.
For players looking to move beyond traditional farming methods, Lineage Support hunting offers one of the most exciting opportunities in Path of Exile 2. One lucky boss kill could be all it takes to walk away with a drop worth more than 100 Divine Orbs.
Here is an exclusive promo code just for gamers: enter "candy" to unlock special player perks and buy POE2 Currency enjoy a 5% discount on your purchase!
