U4GM ARC Raiders Guide to China's Rebellion PvE Mode
Postat: 01 jun 2026, 05:36
av Blustery
ARC Raiders has always lived on that awkward little pause before you trust another player. In the Chinese closed beta, though, Embark Studios is testing a version of the game where that pause feels very different. On the Dam Battleground map, raiders don't automatically hurt each other anymore, which makes looting, routing, and even chasing ARC Raiders BluePrints feel less like a coin toss and more like a planned PvE run. It's not a small rules tweak. It changes the mood of the match from the first few seconds.
How Rebellion changes the lobby
The new system is called Rebellion Incident, and it works like an opt-in betrayal button. Everyone starts as a working ally, at least on paper. Your shots won't damage another human player unless you choose to defect. Once someone does that, the game doesn't keep it quiet. The whole lobby is warned, and the player who turned rogue gets marked with a red icon on both the compass and the map. There's no sneaky reset, no slipping back into the crowd. If you start the fight, you carry that choice for the rest of the raid.
More loot, less paranoia
What stands out is the reward structure around it. Since the normal threat of human ambushes is toned down, the Chinese test build raises resource density across the map. That's a big deal for new players. In the global version, you can lose a good run because someone waited by an exit for three minutes. Here, beginners get more room to learn enemy patterns, gather materials, and actually leave with something useful. It won't please everyone, of course. Some players come to ARC Raiders for that ugly, nervous chaos. Others just want a fair shot at progress without being farmed by veterans every evening.
The Two Queens adds pressure from another angle
Embark isn't simply making the game soft, though. Another tested condition, The Two Queens, puts both the Queen and the Matriarch into the same match. That's a nasty PvE setup. It asks squads to spend ammo, move properly, and decide whether the extra supplies are worth the trouble. This is where the Chinese beta gets interesting. Instead of relying on player killers to create danger, it tries to push tension through bigger enemy encounters. You're still under pressure, just not always from a stranger with a rifle hiding near extraction.
A split that says a lot about the audience
This test also shows how far regional live-service design can bend. The global client has built its reputation on uncertainty, with Nexon reporting more than 16 million units sold in early 2026 and a core crowd that clearly enjoys the stress. China's build is chasing a different rhythm: safer early raids, heavier PvE, and more generous loot. Players who prefer planning routes, collecting gear, or checking where to buy ARC Raiders Bps may find that approach easier to settle into, while the global version keeps feeding the high-risk stories that made the game take off.
