U4GM ARC Raiders Quest Guide: A Dead End
In ARC Raiders, the quest "A Dead End" takes players into the underground sections of the Blue Gate map as part of Shani's storyline in the Shrouded Sky update. It's a tense mission because of the game's extraction-style rules—if you die before securing the quest item in a Safe Pocket, you'll have to start over in another raid. Because of that, preparation and quick decision-making matter a lot more than just charging through enemies ARC Raiders Coins.
The quest begins by heading to the Reinforced Reception building near the center of Blue Gate. It's a noticeable structure with several zipline elevator shafts that lead underground. Dropping down one of those shafts takes you to the basement area, where you'll know you're in the right place once you see the large Mantikor logo on the wall. Starting here saves time and keeps you from wandering across the surface where other players or ARC enemies might spot you.
From the basement lobby, follow the blue line painted along the floor. It leads through a tunnel into the Security Wing, where you'll run into a large shutter door with a red indicator light. Next to it is a console that requires three power cells to activate. The cells usually spawn in a high-voltage power box back in the reception area nearby, but there's a catch—you can only carry one battery at a time. That means running back and forth several times to power the door.
If you're playing in a squad, this part is easier since teammates can grab batteries while someone else covers the area. Solo players have to move carefully because the location is known for good loot, which makes it a popular place for ambushes. Staying aware of other players and listening for movement helps a lot during these battery runs.
After all three batteries are inserted, the door opens and reveals a room full of valuable gear and the quest items you need. In the back-right corner there's an old terminal. Interacting with it plays a recording connected to Project Heartwood and advances the objective. Once that's done, check the cabinets on the opposite side of the room. One of them contains the Dusty Film Reel, which drops out when you search it. Make sure to place the reel in a Safe Pocket as soon as you pick it up so you don't lose it if something goes wrong during extraction.
The design of the area fits the core loop of ARC Raiders pretty well. Even after finishing the quest, players often return because the battery puzzle resets and the room can be farmed for loot. During the quest run, though, you need to finish everything in a single raid. Since Blue Gate sees a lot of PvP activity, it's common to run into other raiders heading to the same location.
Once you've secured the reel, the last step is getting out safely. Backtrack through the tunnels, take the ziplines back up to the surface, and head toward the nearby Cliffside Airshaft extraction point. Escaping successfully lets you return the film reel to Shani. Completing the quest rewards you with coins, a Warden skin variant, and unlocks the next mission, "A Rising Tide."
Because the area is dangerous and popular with other players, many attempts end during the escape phase ARC Raiders Coins for sale. If the reel isn't in your Safe Pocket, dying on the way out means starting the entire process again. It can be frustrating, but once you know the route and battery locations, the quest becomes much easier. After a few runs, Blue Gate starts to feel less like a trap and more like a place you can navigate confidently.
