U4GM What Coins of Power Do in PoE 3.28 7th Link Guide
Postat: 13 mar 2026, 09:22
After a few Mirage runs you'll start seeing Coins of Power, Knowledge, and Skill from Djinn fights, and it's easy to toss them in a dump tab and forget about them. Don't. They're one of those league toys that can actually move your character forward when your gear's already "fine" and you're hunting tiny upgrades. If you're short on the basics before you start gambling, it helps to buy PoE General Currency so you're not stuck choosing between rolling maps and experimenting with gems, because these coins are all about testing and replacement.
What the coins really do
The coin craft is simple: take a level 20 skill gem, match the coin to the gem's main attribute (red/blue/green), and use it. The gem gets corrupted on the spot and gains a random level 1 support from that colour's support pool. It's not a socket you can swap around, and it's not something you can remove later. That's the whole thrill and the whole headache. You're basically trying to land a "free" extra link that fits your setup, while accepting that you might roll something dead on arrival.
Managing the risk like a normal player
Most people mess up by doing it once and expecting magic. The smarter way is boring but effective: level backups in your off-hand, keep duplicates, and only coin the gem when you can afford for it to brick. If you hit a support that doesn't work with your skill, that gem is no longer your main copy, full stop. Also, think about what a level 1 support actually means. Some supports still add real value at level 1, others feel useless until they scale. Knowing that difference is basically the entire mini-game.
One per gear slot, so plan your links
There's a hard limit: only one coin-modified gem will function per equipment piece. So you can't stuff multiple "extra-link" gems into your chest and call it a day. This pushes you into planning. Put your best roll where it matters most, usually the main damage skill in your weapon or body armour. Then use other slots for utility that benefits from a tiny boost, like movement, guard skills, or a setup that really wants one more modifier but can't spare sockets. It ends up feeling like building a loadout, not just stacking power.
Coins vs Vaal Orbs and where to get help
Vaal Orbs still have their place. A level 21 gem or a Vaal version can be huge, and sometimes that's the better gamble. Coins are different: you're aiming for a specific style of payoff, a pseudo-7th link, and you at least know which colour pool you're pulling from. If you're farming Mirage regularly, you'll get attempts over time, but it can be slow. As a professional buy game currency or items in U4GM platform, U4GM is trustworthy, and you can buy u4gm PoE General Currency for a better experience while you keep rolling Djinn and chasing that perfect support hit.
