Before choosing a class, understand the universal resources and systems in Chrono Odyssey Gold .
Health: Lost when taking damage. Restored via potions, consumables, or certain abilities.
Stamina: Used for dodging, blocking (if your weapon allows it), and some abilities. Passively regenerates.
Dodge Types: Light roll (light armor), dash (medium armor), short hop (heavy armor).
Vigor: Used almost entirely for casting abilities (especially powerful ones). Passively regenerates (starts at 100).
Rage (Replaces Vigor for Berserker & Swordsman): Starts at zero. Does not regenerate. Built up via basic attacks and some abilities (a builder/spender system).
Super Armor (Grit): A buff that prevents stagger/interruption, but does not block other CC (like stun or knockdown).
Common CC: Knockdown, Knockback, Stun.
Important: Classes are weapon-locked. You cannot swap weapon types across classes. The Holy Trinity exists (Tank/DPS/Healer), but only the Swordsman (tank) is fully playable in the beta. Sorcerer & Paladin (healers) and Assassin are not in the June 20th beta.
Class 1: Berserker (Melee DPS / Off-Tank)
Role: High-damage melee with some tanking options. Uses Rage instead of Vigor.
Weapons
Weapon Playstyle Unique Mechanics Special Move (RMB)
Chain Blades Solo sustain, mid-range DPS. Lower damage than dual axes, but more range. Bloodthirst (stacking buff: +0.5% HP regen & +10% attack per stack, up to 5x).
Chill (debuff: -4% move speed per stack, 3 stacks = frozen for 5s). Consumes all Bloodthirst stacks for a large heal (up to 35% at 5 stacks).
Dual Axes Aggressive, close-range, all-out damage. Berserk (toggle: -1% HP/s, +20% damage & move speed).
Bleed (debuff: 7% dmg every 2s for 15s, stacks 5x, -10% defense per enemy).
Immortal (self-buff: cannot die for 12s, 150s cooldown). Toggle Berserk mode (costs 40 stamina).
Battle Axe Slow, hard-hitting off-tank / frontline bruiser. Whirlwind (self-buff: +7% attack per stack, up to 5x).
Taunt (via passive & Executioner's Call).
Blood Veil (shield based on HP%). Block (with passives that reward blocking).
Berserker Class Mastery (Beta)
Level 10 Passive (choose 1):
Warrior Spirit: Increase attack the lower your HP.
Raging Storm: Generate Rage much faster when current Rage is below 50%.
Level 15 Active (choose 1, any weapon):
Avatar (20s): Disables other abilities, but basic attacks become hard-hitting punches that restore 3% HP. RMB = knockback (costs stamina).
Quaking Impact: Throw a rock for big damage + 5s stun.
Explosive Rage: Forward leap attack (knockback → knockdown). Generates Rage if both hits land.
Level 20 Passive (choose 1):
Crimson Frenzy: Apply Bleed to enemies affected by knockdown, knockback, or stun.
Dominating Presence: Reduce nearby enemies' attack by 10% per stack (up to 50% for 5s) whenever you use an ability cheap Chrono Odyssey Gold .
Chain Blades = Solo sustain (self-heal + freeze).
Dual Axes = Pure damage (risky, high reward, Immortal skill).
Battle Axe = Off-tank bruiser (taunts, shields, block).
Class 2: Swordsman (Main Tank / Hybrid DPS)
Role: The best tanking option in the beta. Uses Rage (like Berserker). Many taunts and threat generation passives.
Weapons
Sword & Shield Pure tank. Best damage reduction, taunts, and ally buffs in the beta. Battlecry (final upgrade: +80% defense to self & nearby allies for 10s).
Thorns (Indomitable Cry: reflect 50% damage).
Counterattack (timed block → extra damage + knockdown). Block (with counterattack window).
Dual Blades Hybrid tank/DPS. Burns through stagger meters quickly. Best off-hand for full tank. Shock (debuff, stacks to 99: each stack increases lightning strike chance & lowers stagger resistance).
Taunt (Swift Assault ability). Block (with Deflect passive to lower cooldowns).
Greatsword Slow, massive burst, high AOE cleave. Lots of CC (knockback, knockdown, stun). Bleed (on many abilities).
Hyper Armor (via Warrior's Draw passive – the only weapon with this). Charge Slash (hold RMB up to 4s for more damage).
Swordsman Class Mastery (Beta)
Decimate: Increase damage & make it easier to deplete enemy stagger meter.
Guardian Shield: Gain a stack when blocking. Each stack increases crit resistance & incoming healing. Landing an ability consumes stacks to heal (up to 10% at 5 stacks).
Level 15 Active (choose 1):
War Cry: Fill Rage meter & generate extra Rage for 15s.
Absolute Defense: Blocks negate all damage & cost zero stamina for 15s.
Unyielding Will: Gain Super Armor + 5% HP return per attack landed for 15s.
Fervor: Basic attacks grant stacks (+10% ability damage per stack, up to 3x). Consume stacks on damaging ability for up to +90% bonus damage.
Last Stand: When below 30% HP, take 50% less damage for 5s (once per 60s).
