How DS Forever Runs on the AYN Thor
This setup relies on DS Forever, an unofficial launcher and companion app built by Jreese702. It mixes WoW Forever Android Launch and GameNative so compact controls can handle a PC MMORPG. Powered by the Thor's Snapdragon chip, it runs the PC version through Wine/Proton, DXVK, and a custom Turnip graphics driver. Those terms sound like alien jargon, yet they are common tools on Android handhelds.
Second-Screen Tools for Questing
A second screen shines in a long, quest-filled MMORPG where quick reference keeps you moving. DS Forever puts helpful details right on the lower display.
Maps with color-coded indoor layouts by exit and floor
NPCs you have already encountered
Quest data from the Questie add-on database
Topic Key Requirement Helpful Note
Game Copy Folder with .build.info and Data Keep about 60 GB space free
Account & Client Active sub/game time and own files DS Forever does not include game
App Install Latest GitHub release APK Do due diligence and allow unknown sources
Two-Screen Setup Seven checks, map art, quest DB Tap Try again if any check fails
Basic Steps to Get Playing
Always follow the developer's GitHub instructions since updates happen almost daily. You need an active WoW subscription or game time and your own game files because DS Forever does not include the game. Copy your game folder—tested in Documents/WoW Forever on internal storage—with roughly 60 GB free.
First Launch and Updaters
Download the latest DS Forever APK from GitHub releases, allow installs from unknown sources after doing due diligence, and install it. Grant file access, choose your game folder on first launch, and run the two-screen setup. It runs seven required checks, prepares map art from your game files, and downloads the quest database before Play unlocks; tap Try again if anything fails. Sign in through Configure Login, approve any authenticator manually, hit Play, and use the built-in updaters for app and client.
Controls, Hardware, and Extra Notes
Expect lots of button mapping and configuration since a PC game is running on a compact handheld. At this time, the app only works with the AYN Thor and has not been tested without dual-screen devices like the Retroid Pocket Duo, so a higher-RAM model is recommended over Lite or Base.
Policy Notes and Where to Look Next
The project reportedly does not violate Blizzard's terms of service, though doing your own research is smart, and AI tools assisted in building it. Make sure to visit CD's Retro Corner for more information. For players looking for extra help pushing through tough content on a tight schedule, cheap World of Warcraft Forever Boosting can be an option to consider. Looking into cheap World of Warcraft Forever Boosting can also help keep progression steady when time is short.
Looking to take this a step further? Read our follow-up piece on other topics:
1. WoW 12.1.7: Beat the Aqir Reward Price Increase: https://www.u4n.com/news/wow-12-1-7-bea ... rease.html
2. WoW Forever Nov. 23: Energy Fixes and World Buff Rules: https://www.u4n.com/news/wow-forever-no ... rules.html
3. WoW Forever PvP: Know the Risks Before You Commit: https://www.u4n.com/news/wow-forever-pv ... ommit.html
